Code 33
Old Sep 22, 2002 | 05:15 PM
MLTurner's Avatar
Code 33
I keep getting this MAF code. I've installed a new MAF and still get this Code 33. I should say that it is not all the time. If I shut the vehicle down for 60 seconds and restart it will be fine for a time. I've have just rebuilt the motor. Installed speedpro 10/1 pistons & SLP runners,Chevys Hot Cam, port work on heads& intake system. New headers. just trying to find the problem. Any ideals will be HELPFUL,,,,,,,,,,,
Old Sep 23, 2002 | 03:20 AM
drive it's Avatar
First make sure that the relays are good, no shorts, adjust the throttle blades so your iac is about 20's at isle. If that doesn't do it-with your mods, you need a chip burned-there's a table under ecm constants-maf high diag (code 3) error-change from 45gps to about 100gps; it'll still set a code for a real problem and that'll get rid of the false code that your mods produce.
Old Sep 23, 2002 | 09:42 AM
Vader's Avatar
A DTC 33 is for unexpectedly high measured flow. Make sure the TPS is adjusted correctly.
Old Sep 23, 2002 | 05:37 PM
MLTurner's Avatar
Thanks, Ive set the TPS and IAC(new)
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
