Can you use domed pistons with Vortec heads?
Old Sep 24, 2002 | 09:56 AM
Bryant's Avatar
I have a destroked 400 (350 crank) with approx 12.5 compression (no street use). I'd like to know if the Vortec head combustion chambers will clear the domes. If so, I can get it running with some simple spring/guide/stud work and worry about upgrading heads next year.
Old Sep 24, 2002 | 04:24 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
How far above the deck surface do the domes stick up? This will be the big factor. The Vortecs are very similar to other 64cc heads.
Old Sep 24, 2002 | 04:33 PM
ede's Avatar
ede
depends on the dome height, ideally you'd want a small chamber and dished pistons. reguardless of what set up you chose you should dummy up one head and 2 valves at least and measure the piston to valve clearance.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
C409
Sep 23, 2015 04:30 PM
Mickeyruder
Sep 2, 2015 02:45 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
