oil pan gasket
Old Sep 25, 2002 | 01:07 PM
holmes677's Avatar
oil pan gasket
I have a blue Felpro 1 piece rubber gasket for my 84 Z 305 oil pan. I was told to install this gasket dry, is that true or should i use some type of silicone. If so, should i put it on both sides of the gasket or just on the oil pan or just on the block. Im new to working on cars and i would apprciate all the help i can get.
Old Sep 25, 2002 | 01:25 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Install the gasket dry, just use 3M spray glue to stick it to the block.
Old Sep 25, 2002 | 01:27 PM
holmes677's Avatar
alright, will do, thanks for the info., much appreciated.
Old Sep 25, 2002 | 02:31 PM
holmes677's Avatar
Just one more question on the same note. Im putting on new rubber valve cover gaskets with the perimeter bolt pattern. Should i use any silicone?
Old Sep 25, 2002 | 03:41 PM
holmes677's Avatar
does anybody got an idea?, in kinda in a hurry,
thanks.
Old Sep 25, 2002 | 03:57 PM
Fast3rdGen's Avatar
no silicone
Old Sep 25, 2002 | 06:10 PM
ede's Avatar
ede
i use ultracopper to stick the valve cover gasket to the valve cover
Hotrodboba400
Dec 10, 2019 07:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
