does the computer do anything different when ur in drive then when in park?
Old Sep 26, 2002 | 03:48 PM
breathment's Avatar
ok i know that subject line didn't make any sense. but here it is explained better.
I just swapped a t-56 into my car. and left the stock auto shifter in the car with all the wires connected to it.. well its sitting in the passenger seat.. but i know that it has to be in park or neutral for the car to start (until i can hook it up to the clutch pedal).. so right now i just leave it in park position all the time.. start the car and drive.. but im starting to wonder if maybe that signal from the auto shifter goes to the comp.. and if it thinks it is in park the whole time if maybe it will be screwign something up?? should i start it. put the auto shifter into the D position and drive it like that? cause im not getting any codes or anything and i thought i should be getting a T.C. or VSS trouble code..
Old Sep 26, 2002 | 04:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I'm not sure, but I think the computer does something about the idle speed in park and neutral?
Old Sep 26, 2002 | 06:47 PM
Marin's Avatar
The ECM works differently in Park/Neutral. You can just search for Park in the code.
Here's the commented code for your car ('86-'89 TPI)
http://www.diy-efi.org/gmecm/ecm_info/1227165/bua.a
Old Sep 26, 2002 | 08:52 PM
breathment's Avatar
thanks :hail: i just wish i could understand half of that...
ill just put the shifter into drive until i can get it wired up correctly
1992rs/ss
16
Jan 28, 2016 09:58 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
jharrison5
Aug 19, 2015 05:53 PM
Bryan F
Aug 18, 2015 02:28 PM
