Hold on....
Old Sep 27, 2002 | 09:53 AM
92bird's Avatar
Hold on....
Well, now i went out and it started right up, battery gauge is showing good now, before it had been almost dead hmmm, what is happening?? Thanks for any info.:hail:
Old Sep 27, 2002 | 09:54 AM
92bird's Avatar
Sorry I am really out of it today really bad week, i meant to reply to my original topic "car is dead" my apoligies.
Old Sep 27, 2002 | 11:08 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Excuse to ***** it!!
Hmm, that is weird though, that it would just start working again.
Old Sep 27, 2002 | 11:13 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Not if there were a loose ground to the battery, used to happen to me a lot.
92bird's Avatar
Yes, but it has done this before.... probably some water is getting into the engine and having some fun, oh well class on fridays always suck anyways.
Old Sep 27, 2002 | 11:15 AM
92bird's Avatar
Loose ground?
That might be the case, however, why would it just start back up again ....I tried moving the battery cables to no avail, so I think it isn't that. Where else could I check? .
Old Sep 27, 2002 | 11:51 AM
Car: 99 Formula
Axle/Gears: 342
Re: Loose ground?
Did I see in your other post that the lights at least work? If so, then it's not the ground.
Old Sep 27, 2002 | 11:52 AM
92bird's Avatar
Yes
Ya lights came on, but when I tried to turn the engine on, they dimmed however, later it now works..... I am pretty pissed because I just missed some BS class that I had a quiz in. What a friday.
Old Sep 27, 2002 | 12:15 PM
92bird's Avatar
My mechanic said....
I just talked to a friend that works at a body shop, he seems to think it might be injector fuses.....I know very little about that could that be the problem??
Old Sep 27, 2002 | 12:29 PM
irocbsa's Avatar
Now way in hell. If the inj. fuse took a crap you could still turn the engine over. It would spin but the injectors wouldn't be pulsing so no starty. Its something in that starter circuit. The starter may still be bad. I've got a starter on the way out and sometimes it will click once or twice before turning over. I wouldn't be listening to that friend of yours anymore.
Old Sep 27, 2002 | 12:40 PM
92bird's Avatar
irocbsa Now way in hell. If the inj. fuse took a crap you could still turn the engine over. It would spin but the injectors wouldn't be pulsing so no starty. Its something in that starter circuit. The starter may still be bad. I've got a starter on the way out and sometimes it will click once or twice before turning over. I wouldn't be listening to that friend of yours anymore.
Ya, didn't think that was on at all.....
RedLeader289
May 28, 2019 01:47 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
mattcanty
Oct 12, 2015 11:08 AM
Briandrex
Oct 5, 2015 06:20 AM
racereese
Oct 3, 2015 03:46 PM
