What happened?
Old Sep 28, 2002 | 11:33 AM
iroc-j's Avatar
What happened?
Recently my alternator died out and i needed to replace it, so autozone pulled up my 86 305 tpi camaro and gave me the alternator. When i went to put it in, the alternator they gave me was clocked at 12 and i needed to clock it at 3. One of the guys at autozone suggested there might have been an engine swap, the only signs of this are a hose that is not connected and my a.c. is also not connected. Is their any way to tell? Or could the alternator just have been changed and used different brackets?
Old Sep 28, 2002 | 11:37 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Check the block #, should be on the driver side of the block.
Old Sep 28, 2002 | 04:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That happens alot... the same alternator fits lots of different cars except for how it's "clocked", so they just keep the one in stock, and you have to move it if your car needs iit somewhere else.
Old Sep 28, 2002 | 07:12 PM
CamaroDriver's Avatar
OK. You guys lost me
What does it mean to "clock" an alternator?
Old Sep 28, 2002 | 09:44 PM
RICHRAD's Avatar
I believe they are talking about the position of the terminal/connectors in relation to the mounting holes....I think
Old Sep 29, 2002 | 09:27 AM
iroc-j's Avatar
The only thing on the engine is a small sticker w/a barcode that says 5205, i think.
Old Sep 30, 2002 | 01:33 PM
iroc-j's Avatar
What causes the backfire sound out of my exhaust when i rev the engine?
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
