rough engine after 45 minutes
Old Sep 29, 2002 | 07:55 AM
RFONT54's Avatar
i Have an 89 rs 2.8l. runs great for 45 minutes after that no power engine back fires and will not accelerate. i replaced the cap,rotor,wires,plugs,tps,iac,vaccumm hoses, airfilter, air pump check valve. air pump pipe, removed the cat, noe the only weird thing is the timing is set at about 25degrees or else the car is so sluggish its like a 4 cylendar. timing chain is next. any other suggestions?
Old Sep 29, 2002 | 09:31 AM
Kevin Johnson's Avatar
Re: rough engine after 45 minutes
Do any codes come up?
Old Sep 30, 2002 | 03:10 AM
FU-Q's Avatar
if you replaced that many thing allready you might as well replace your ignition modual too $13.99.
see what happens...
Old Sep 30, 2002 | 04:37 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Yes ...ignition module...may be heating up and shorting out,,you may want to check the pick-up coil also.
Old Oct 9, 2002 | 07:05 PM
RFONT54's Avatar
replaced the module p/u coil and dist. oil o-ring. engine runs great and my oil leak is gone thank you. this one had me stumpped. however i have conqured all air conditioner problems you could encounter so if any questions just ask
Old Oct 10, 2002 | 04:16 AM
Engine: 406
thanks for the update..glad you got it fixed..
jbd1969
Aug 17, 2015 07:06 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Sherpajames
Aug 7, 2015 06:56 PM
