need an educated guess on rpm here
Old Sep 29, 2002 | 01:31 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
not really a problem, more just curiosity.
my engine is essentially a stock 84 lg4. all mods are listed in sig.
its got performer intake, holley 600, and the cam listed below. heads are completely stock aside from normal engine rebuild procedures. yes i know it needs different springs. my main question is how many rpm can i safely(in drag race situation) turn on the stock bottom end and other parts?
don't be afraid to answer, i won't hold anyone responsible if i try your suggestion, and get bad results
Old Sep 29, 2002 | 03:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The stock bottom end is good to about 6k. But the combination you have listed will have long sice ceased to rpoduce meaningful power well before that, so it's probably not an issue unless you miss a gear. It will probably go the fastest shifting somewhere between 4800 and 5200.
Old Sep 29, 2002 | 03:56 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Shifting at around 5k seemed to work ok for me when I had my LG4.
pjsparts
Oct 29, 2025 06:39 PM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
