oil pressure/sending unit??
Old Sep 29, 2002 | 06:26 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Hello all,
I have a question about my oil pressure. I have a 1989, Firebird, 305, TBI, CA emissions. New motor, less than 15K. The oil pressure gauge on the dash is acting very funny. At hot idle it reads about 32-35 psi, (which is normal to this motor), but when I take off/give it fuel the gague goes to the max limit very qucikly!!, not an even movment but very fast. The dash gague is about 6 months old, Can somebody tell me if this is the oil sending unit or what ever else I need to do to Trouble shoot this prob. Before this problem arised the max oil pressure I would get (cold motor) was 58psi then once it warms up \its about 40 psi. I really dont think the motor has over 65 psi pressure at all times. Any ideas and suggestions will be greatly appreicated. Thanks in Advance
Brad
Old Sep 29, 2002 | 07:23 PM
JOHN/88IROCZ's Avatar
My oil sender and stock gauge is new. At idle it is around 30-40 psi at at any amount of throttle it maxes the stock gauge at 60 psi. I dont think there is anything wrong with yours just good oil preasure. I run sae 30w Valvoline. If you run a synthetic like Mobile one the oil preasure might run a little lower due to a thinner but better oil.
Hotrodboba400
Dec 10, 2019 07:07 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Glowsock
Sep 5, 2015 07:48 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
