Simple block question.
Car: 89 Firebird
Whats the diff. in 305, 350, and 400 ci engine blocks? I always have the most trouble with the easy ones
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
the bore mainly. The 305 and 350 had the same stroke, but due to the 305's water jacket configuration, it can't be bored to a 350(that probably answers your next question). The 400 used a longer stroke and a slightly bigger bore then the 350. A 350 with a 400 crank makes a 383 and a 305 makes a 333 or something along those lines, furthering the SBC's problem with long stroke/small piston. A 400 with a 350 crank makes a motor that makes less torque but screams to an ungodly redline.
RyanJB
Sep 14, 2015 03:39 PM
