Does this rear end exist..
Old Oct 1, 2002 | 04:59 PM
Bugsy's Avatar
Ok, I have a 91 Z28. I'm looking for a used rear end with 3.42 gears on a posi drum. Does this exist?
I know the 91/92 305cc G92 upgrade had the 3.42 ratio but were these still drum or all changed to disc?
Also, does anyone know if any of the older camaro rear ends with 3.45 ratio have posi drum?
Thanks!
Old Oct 1, 2002 | 05:03 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
yes, the 3.42 posi drum does exist. i am in fact lookibf for one also. a lot of the V6 cars got 3.42 gears and had drum breaks...
Old Oct 1, 2002 | 06:31 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
The 3.45 is a 9 bolt ratio. 99.9+% of all 9 bolts are posi disk brake units, but a few drum brakes and few open carrier units do exist.
Miles
Diff Solutions
www.9bolt.com
Old Oct 1, 2002 | 08:16 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
I have one such car.....
Old Oct 1, 2002 | 08:44 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
yup.. got drums with 3.42 gears.
Old Oct 1, 2002 | 08:55 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
If the RPO code sticker is in the car look for GU6 (3.42) and G80 (posi). Those are the RPO codes for our cars. But I don't know about the carriers and axle splines. I think they didn't go to 28 spline axles until 89, so look for that year or newer.
AJ
Old Oct 2, 2002 | 04:51 AM
Engine: 406
AJ
it can go either way in 89....90 up for sure has 28 splines..if you have an 89 you have to count to be sure..
Old Oct 2, 2002 | 05:47 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That would be an extremely uncommon combo, if it exists. But not hard to create yourself of course. Go find one of the 6-cyl 3.42 drum rears, then just put one the the SLP posi units in it.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
