Help: Smoke from air cleaner after car turned off
Old Oct 1, 2002 | 10:39 PM
Nokternal7's Avatar
I have a Carburated 83 Trans Am. After I turn the car off I can see white smoke coming out from the air intake that attaches to the air cleaner assembly. There is a hole on the bottom of that intake about halfway up between the front of the car and the air cleaner. Thats where the smoke is coming from. Sometimes its there when the car is on, but you can really see it after the car is turned off.
Any ideas?
Old Oct 1, 2002 | 11:41 PM
Kevin Johnson's Avatar
Sounds like gas vapors or oil fumes from the crankcase. Have you looked inside the aircleaner? The little foam element might have dropped out or might be missing from the PCV inlet.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
86IROC112
Aug 17, 2015 02:00 PM
