replaced plugs now idle feels rough
Old Oct 2, 2002 | 10:43 PM
tamonez's Avatar
Car: 88 Iroc
Transmission: 5 speed
I just replaced my spark plug with bosch platnum when I started the car for the first time the idle felt rough. do they take a while to get worked in? does it take time from the computer to recognize them? did I not properly connect the boot or did screw the plug all the way in?
I unplugged the battery before I started
the car accelerates good no problem there just the idle.
any one ever had a similar situation help is greatly appreciated
Old Oct 2, 2002 | 11:18 PM
90FirebirdV6's Avatar
I tried those bosh plat plugs and the +4's I had a problem where it would idle weird or if you rev'ed it up a little and let of the gas it would miss, or it didnt have good performance. I switched to the cheap autolites and it fixed everything, id try picking up a set of the 0.99 autolites seeing if that fixes it.
Old Oct 2, 2002 | 11:23 PM
rezinn's Avatar
Any new plug should work well enough that the car runs smoothly. Check the plugs to make sure they are tight, the wires are on correctly and not burned through, and make sure the wires are on in the correct order. That's all I can think of. If this doesn't work you may have a defective plug or one that's gap got closed off when dropped or put in.
Old Oct 3, 2002 | 12:52 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
if you had the computer unplugged for awhile, you have to drive her so the computer can "re-learn" what its supposed to do. i just did a full tune up on my TA and i had the battery unplugged for a few hours. when i started her she idled alittle rough, not too bad, but still noticable. they say to drive above 40mph for 20 mins to let the computer catch up. just my idea... also make sure all your wire connections, both at the plugs and the dist are secure. hope it helps.
justin
Old Oct 3, 2002 | 01:29 AM
Sciguyjim's Avatar
A lot of people complain about the Bosch plugs. Seems to be best if you stick with the same design the car came with. Personally I like AS Delco Rapidfires.
Old Oct 3, 2002 | 06:25 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Check the wires to make sure that they are attched properly. I've had the samething happen a few times on me. The car would have a slight miss in it and just run rough generally.. So I checked the wires and one was sorta half way on there. Popped back on and all was well again..
Kat
Old Oct 3, 2002 | 12:48 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
The same like ghetocruiser said.
The IAC has 256 positions (steps), these steps varies from 0 to 255 between 0 to 40 MPH (app. 65 KMH). Your IAC and ECM needs "re-learn" and review the 256 steps before the normal idle return (= run the car from 0 to 40 MPH, then continue over this speed for a short time).
Then, if you fix this first problem, you can search for others possibilities (if the bad idle continue).
Regards,
Denis V.
Old Oct 4, 2002 | 04:11 PM
tamonez's Avatar
Car: 88 Iroc
Kat
I went out and gave all the wires a little push. took the car out for a spin and Problem Solved. Thanks
Old Oct 4, 2002 | 05:17 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
It's not your wires, it's not your cap, it's not your rotor, it's the plugs, i spent $48 on a set of platinum+4's, they ran like crap, replaced every other part of the ignition, still didn't help, went to ac rapidfires and it turned right over, every cylinder fired, idled smooth. I have no idea why, but it seems like 4bangers are the only ones that can make bosch's work.
Old Oct 4, 2002 | 05:25 PM
Engine: V8
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
db057
Aug 22, 2015 08:17 PM
mizz0313
Aug 12, 2015 06:45 AM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
