What weight Oil in Car
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'm switching over to syn in my 90 Lumina Car has 134,500 on it. Burns 0 oil Leaks 0 Oil. Stays at FULL all 4,000 miles. Should I go with Mobil 1 10-30 or 15-50? I use 15-50 in My maxima which has 115,000 on it and formula with 70,000
Car: 91 RS
Engine: 350 TBI
I use Mobil 1 Syn. 10-30 in mine, but I have a valve cover leak, so I can't vouch for it beyond that. But I did get the 5 quart jug from Wal-Mart for $11.40
Car: 99 Formula
Axle/Gears: 342
Car: 91 RS
Engine: 350 TBI
I think it was supposed to be closer to $17, but when she scanned it in, that's what it came up to. I spent $11.40 on Syn. oil, and $8 on a K&N oil filter for a whopping grand total of $19.40. Woohoo!...take that quick lube place. That's cheaper than a standard oil change with a piece of sh*t filter.
I've been using Mobil 1 5w-30 for 13 years. This year I added 2 quarts of 15w-50 to raise the viscosity a bit for the hot summer. Oil pressure is good of course, but oil flow is more important for cooling and flushing particulates. Also, a too-thick oil is harder for the engine to work with so it makes the engine temps rise. I once used only 15w-50 oil and the car was noticably sluggish from fighting the extra thick oil.
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i'm with ede on this one. i myself run 20-50. here in texas there is no need for thin oil though
. There's a similar thread going on now at:
https://www.thirdgen.org/techbb2/sho...hreadid=135669
You might also be interested in this thread:
https://www.thirdgen.org/techbb2/sho...hreadid=134240
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
