a question or two
Old Oct 7, 2002 | 09:04 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
a question or two
i'm looking at a Summit 350 rebuild kit.............
it says that compression will be approx. 9.72:1 with 64 CC heads
i have a set of cast iron 58CC heads
will the compression be too much for the street/ pump gas?
Old Oct 7, 2002 | 11:56 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
All else being equal, going from 64cc heads to 58cc will raise the comp ratio from 9.72 to 10.4:1.
That's pushing it on an iron head motor. Your cooling system will have to be in 100% condition, and it also depends on what cam you're going to use, as well as the timing curve.
Are you going to use a mech. adv. dist. or CC? What cam are you going with?
AJ
Old Oct 7, 2002 | 01:41 PM
AJ
Old Oct 7, 2002 | 01:42 PM
i guess i should go with the thickest head gaskets i can find, huh?
Old Oct 8, 2002 | 12:08 AM
AJ_92RS's Avatar
That calculation was using a .040" gasket, which is about as thick as they come. Any thicker and you may as well not even bolt the heads on because it's gonna leak just the same.
AJ
Old Oct 8, 2002 | 01:50 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
1991,
Shouldn't be too big a deal. If you want a lot of insurance then polish the combustion chambers. Not only will this increase the cc but will get rid of heat risers which cause predet. this will allow you to use 92 with pretty much whatever initial adv. you choose. So pick up that diegrinder .
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
