Head lift question
Old Oct 7, 2002 | 06:30 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Head lift question
What is the max lift the stock 305 heads will hold on a TPI 305 in a 89 IROC?
Brian Felts
Old Oct 7, 2002 | 07:36 PM
ede's Avatar
ede
my personal limit is in the .460 range, lot of people go more towards .500
Old Oct 7, 2002 | 08:03 PM
I know the vortecs will only take .460 I found it out the hard way, I destroyed the guides with the lt4 cam. I was afraid the to assume the 305 heads would take even that much......so thanks for setting me up with the info. I may look into a LT1 cam for my newly found 305 TPI
Brian
Old Oct 7, 2002 | 08:21 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Brian
If you ask 20 people you'll likely get 20 different answers.
Should have learned by now to just check for yourself.
takes all of 5 minutes.
Old Oct 8, 2002 | 02:09 PM
The problem right not I don't have the time or the correct tools to make a exact measurement. I was wanting some knowledge for the future.
Now if you can tell me how you can dig down to the valve covers and pull one off.......take the rocker lose......remove the valve spring......attach a guage and a test spring all in 5 minutes?
Thanks for your help
Ede
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
anesthes
Aug 8, 2015 09:37 PM
