1/4 mile time
Old Oct 7, 2002 | 07:30 PM
pskel350's Avatar
1/4 mile time
i just had my camaro put on the dyno, it made 260 RWHP and 335 ft/lb of tourqe. i wont get it to the track until late spring now that i crushed my leg, but i was wondering if any of you could give me an estimate on what you think my 1/4 mile time would be. i have the minor mods, cam, intake, carb, complete exhaust, and 3.42 gears. i am just wondering, thank you.
Old Oct 7, 2002 | 07:37 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Mid 13s, just my guess though.
Old Oct 7, 2002 | 07:46 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Mid 13's like mark said. Maybe with a good TC and traction low 13's.
Old Oct 7, 2002 | 09:20 PM
The Hog's Avatar
Doing the math and guessing 3350lbs it comes out at 13.65.
Old Oct 7, 2002 | 10:06 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
IF this guy should be runnin mid 13's with that basic of a set up then I must be missing something!! I have the base 350 crate engine, and all mods combined i'm at about 380 HP engine and the best run I had with my 700r4 with a shiftkit and 2600 stall on my 3.23 lockin rear was a 14.5 from the g-tech. since then i've put a 350 trans with shift kit, com cams XE 480 lift cam, and putting in a spohn torque arm in a week, still been off the road since the start of all that. Anyone have any input as to what I should have/ or should be running?? Cuz I think I should be in the 13's now, but don't see how he could be. Thx
Old Oct 7, 2002 | 10:15 PM
Car: 99 Formula
Axle/Gears: 342
Well, let's see, we both have the same motor. Same cam. I have diff intake, stock stall with 3:73s. and I ran a 15.49, so something is out of tune in my car, I suspect the carb.
Oh, how are you estimating 380HP with only that cam, I don't see heads listed on your mods there. The stock heads on the Goodwrench motor have 8.5:1 compression and are horrible.
I'd say you can hit high 13s when in tune.
just read your sig, we have diff cams but close, mine is .477/.480 , you're no where close to 380hp with stock heads. More like 300 hp, which would be about 240rwhp or so estimated.
Old Oct 7, 2002 | 10:20 PM
Stingraye's Avatar
Car: 1986 Trans Am
i've got the vortec heads, that's what comes on the gm 350 crate engine. And like it says in my sig, is that i've got the performer RPM intake and 650 CFM edelbrock carb. So the book says that the engine out of the box makes what, I think it's 340 HP & TQ, so with all those mods i should be aroudn 370-380 HP or so. So i just dont' see how he could be runnin mid-low 13's with 260 at the wheels, and at the same rate i wonder if I just have something misstuned or soemthign that i'm not running as good as I should be.
Old Oct 7, 2002 | 10:22 PM
Car: 99 Formula
Axle/Gears: 342
Oh sorry, I thought you meant you had the Goodwrench 350.
I think mid 13s are capable for you, throw in some 3:73s and you'll be good for very low 13s, traction dependent.
Old Oct 7, 2002 | 10:29 PM
Stingraye's Avatar
Car: 1986 Trans Am
K, thx mark, and i'll send u my info on the 3'rd gen meet u'r setting up too. But anyone else have any input as to what they think I or pskel should be running??
Old Oct 7, 2002 | 11:14 PM
The Hog's Avatar
He will run that fast because he has 260HP at the wheels not at the flywheel. Hence the 13's. But IMO 380HP on that crate engine is a rather optimistic guess. 380HP is enough to push a 3350lb car to 12 flat so I would guess you are making considerably less power than 380. Just my $0.02
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
evilstuie
Jan 9, 2020 08:29 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
