Questions about smog pump and cats
Old Oct 7, 2002 | 11:03 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
One of my questions is, is it ok to run a cat without a smog pump? Will it get clogged up if you don't have a smog pumb? and does it make a difference how many miles are on the cat? New, or 80 thousand?
If you don't run with a cat, is that bad for the valves not providing enough back pressure?
Old Oct 8, 2002 | 05:30 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
If the converter has an air inlet it's best to leave the pump in place. No you don't have any worry without a cat. Many guy's here don't run one, gut the old one. If you don't need an emission inspection it's up to you. Problem is that even though I am exempt, here in PA they stilll want all emission components in place. A cat with 80k, well that's your call. At that mileage handle it with care, it's getting tired.
onefreakz
May 14, 2018 12:15 PM
italiano67
Dec 11, 2016 09:21 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
