Q about porting L98 iron heads
Old Oct 8, 2002 | 11:48 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
I've been porting a set of L98 iron heads the past couple of days and from what I have read, you're not supposed to polish the intake bowls and passages. Now this is to create some turbulence to keep the air/fuel mixture mixed up, but does that hold since on TPI since the injectors shoot the fuel directly in the head and it only has six inches or so to travel before the combustion chamber?
Old Oct 9, 2002 | 12:24 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
i remember something a while back that the fuel forms a fine sheet and it cant be reatomized or soemthing along those lines. This is probably caused by the fact that, like you said, their is a lack of apreaciable turbulence near the walls and the fact that the velocity approaches zero at the wall of the runner allows teh fuel to settle out. I dont know if its applicable to a batch fire system like yours wher ethe fuel just sits in the runners but hey, im no expert.
Old Oct 9, 2002 | 02:00 AM
Bort62's Avatar
While the finer points of Laminar flow are going to have to wait Until later in my educational Career, I think the "experts" on this site will agree that polishing your intake tract to a finer than "sanded" finish will have absolutely no positive effect on performance, and may even cause some fuel puddling issues (unlikely with port injection, however )
The best analogy ive ever heard, is think of a River.
The water near the sides dosent flow very fast in relation to the middle, does it ?
So concentrate your time someplace else.
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
Chuck84TA
Jul 15, 2016 09:05 PM
beastin91rs
Oct 9, 2015 07:38 AM
