How do you adjust the shift points on a 700R4 without a computer?
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
The car I bought for my girlfriend is an 85 trans am with a 305 holley non computer carb and 700R4. it shifts WAAAAAAAAAY to early if I try racing people by just putting it in drive. It will shift at 4,500. With the cam/header/gears that car has, it pulls solidly to 6,000 rpms. I'd like for it to at least shift at 5,500. How do I adjust it?
Car: 99 Formula
Axle/Gears: 342
Originally posted by RB83L69
TV cable adjustment and/or a shift kit.
The computer has nothing to do with the shift points in that trans.
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
or find a stock spare governor(just in case) and play around with the current one by grinding off some metal off one of the two weights on it.
good luck
good luck
Car: "02 z-28
Engine: LS-1
The stock TV setting usually results in an early shift. Every TG with an auto I have seen does essentially the same thing. A hair's fiddling with the TV adjust will alter the shift point without resulting in trans damage. Remember an early version 700 won't take a whole lot of abuse without some work.
dhonda200
Aug 11, 2015 11:50 PM
