Valve to piston clearance
Old Oct 10, 2002 | 01:11 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Do you guys think i will have problems with valves hitting the pistons? I have a 357 with flat-top piston and small valve reliefs. The heads will be ProLine Pro Lightning's with 64 or 72 cc chambers. The cam is a comp cams CS XR274 R-10 274 280 0.564 0.570. Which heads will be better for clearance 64 cc or 72 cc? I will be running 2.08 or 2.05 and 1.6 valves. How much does it cost to have piston valve reliefs cut deeper, can it be done with cast pistons?
Old Oct 10, 2002 | 02:48 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
I just want a guess on the probability of probkems. I will do a mock-up to check clearances before runnng.
Old Oct 10, 2002 | 05:23 PM
ede's Avatar
ede
doesn't amtter what we think you should dummy it up and check, but i bet you'll be just fine.
Old Oct 10, 2002 | 06:09 PM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
I've been told that if you are under .600 lift and are using STOCK pistons, you'll usually be OK.
However since you aren't using stock pistons, definitely check!
db057
Apr 28, 2019 07:45 AM
New2Chevy
Sep 28, 2015 12:35 AM
355tpipickup
Sep 13, 2015 11:35 PM
Nick McCardle
Sep 10, 2015 08:36 PM
