need help b4 i screw up
im putting vortecs on my car......what ive been trying to figure out is with those heads you are suposed to run narrow body self alligning rockers.....well i have to have guide plates and studs put on them.my question is what in the world do i do about the rockers.....to much money in this motor to screw it up..............thanks ahead of time
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I'm not sure which type of valve cover is on the Vortechs, but if you are installing guidplates you don't need self-aligning rockers. If the VC are centerbolt, you will most likely need the narrow body.
Car: 99 Formula
Axle/Gears: 342
RedLeader289
May 28, 2019 01:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
