PCV valve and breather questions
Two questions. Can I just attach a breather to my PCV valve rather than it go through the loop? Also, is there a breather that will fit the stock hole on the passenger side valve cover on an L98?
I'm talking about a breather attached to the PCV valve, not instead of it. Will it have the same problem? What about a breather in place of the seemingly useless vent from the valve cover to the TB on the passenger side? Yes I'm using a MAF setup.
1992 Trans Am
May 10, 2023 07:19 PM
