Vacuum guage testing per HPPontiac mag.
Old Oct 15, 2002 | 07:38 PM
Little GTA's Avatar
When reving motor, vacuum drops 1st...why?
While performing a vacuum test per a TPI article in HPPontiac Magazine, my 181K motor checks out ok. One thing I noticed though was that when the accelerator is pressed quickly, the vacuum reading would drop a lot before increasing along with the rpms. You could call it a slight hesitation. Once the reading dropped all the way to Zero as the car cut off. What could cause this? If this can be fixed, I could have better throttle response, right?
Old Oct 16, 2002 | 08:01 AM
Vader's Avatar
It sounds like your engine is reacting completely normally. Test any other engine that is in good operating condition, and you should get similar results.
junior419
Apr 7, 2025 11:35 AM
gta892000
Aug 11, 2019 11:16 AM
85 Jimmy
Sep 30, 2015 07:56 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
andy74
Sep 3, 2015 08:41 AM
