What do you think of this setup?
Old Oct 16, 2002 | 11:25 PM
Nickerz's Avatar
396ci
accel super ram
87-91 (is there any difference?) ported corvette heads
1 3/4" longtubes w/ an x-pipe and bullets
209*/217*, .503"/.522" hydrolic roller
now... is there any way I can make the T5 hold this kind of power without spending a fortune? or am I gonna be looking for a T56... same goes for the rear end.. can I just get a nice posi unit and gears or is this 9" territory?
:lala:
Old Oct 17, 2002 | 03:35 AM
ede's Avatar
ede
SBC? i'd run aftermarket heads and i'd look at a differant intake, but that's just me. if you want a bullet proof set up 9" or 12 bolt would be the way to go and there isn't that much that can be done to a t5 to make it stronger.
Old Oct 17, 2002 | 06:19 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I thought a 396 was a BB, how will those SBC heads fit on it?
Old Oct 17, 2002 | 07:00 AM
280Z28's Avatar
I would go for the T56 over the T5 easily. Plus you KNOW it won't blow up on you unless you are really REALLY putting big power through it.
Old Oct 17, 2002 | 10:57 AM
Nickerz's Avatar
over much discussion yesterday we decided that a 396 (which is done with a 396 stroker kit) wouldnt be worth the money over a 383... so do you guys think that a nice posi unit and gears wouldnt really matter and I would just detonate the rear? Also what intake would you recommend then?
Old Oct 17, 2002 | 12:22 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
A 396 strocker is 3.875 inch stroke
with 4.030 bore block.
I would put a bigger cam..
It could use more duration
Old Oct 17, 2002 | 12:32 PM
Nickerz's Avatar
havent been serious about this **** for a while... forgot it was just an overbore.. lol
Im trying to keep this drivable... think I should go with more cam?
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
