emissions readings. tell me what u think...
now this is with a gutted cat with no air tube going to it. other then that how does the engine seem to be running?
RPMS: 2120
CO2: 11.64%
CO: 0.14%
O2: 4.80%
HC: 148 PPM
NOX: 82 PPM
RPMS: 990
CO2: 11.31%
CO: 0.24%
O2: 4.80%
HC: 984 PPM
NOX: 25 PPM
RPMS: 2120
CO2: 11.64%
CO: 0.14%
O2: 4.80%
HC: 148 PPM
NOX: 82 PPM
RPMS: 990
CO2: 11.31%
CO: 0.24%
O2: 4.80%
HC: 984 PPM
NOX: 25 PPM
With a 3" Dynomax cat with no air tube, no smog pump, 12* initial timing, and 50 psi fp I had 0.23 PPM HC and 6.0 PPM CO...The only emissions device was the cat itself and I am running all other paramaters out of spec - I stil managed to come in under the .80 HC and 15 CO limit. If your testing is anything like IL, you will fail. Invest in a good cat and get it flanged. You will save yourself many headaches. As for how your car runs...Invest in some test and tune sessions at the local drag strip and find out - see what your car like and go from there.
well im not so much worried about passing inspection. i should of said this earlier!!
im more worried about how the car is running.. Like i suspect a bad EGR and possibly bad O2.. thanks
Hotrodboba400
Dec 10, 2019 07:07 PM
