not thirdgen, help with jeep!!
Old Oct 17, 2002 | 05:23 PM
19WS6T/A91's Avatar
i keep getting a gas smell inside, this smell occurs regularly. i have already changed the fuel injector o rings. can anyone help?
thanks,
David
Old Oct 17, 2002 | 10:20 PM
iroc22's Avatar
What kind of Jeep is it?
Old Oct 17, 2002 | 10:27 PM
19WS6T/A91's Avatar
its just a normal cherokee with the 4.0
david
Old Oct 18, 2002 | 09:32 AM
ede's Avatar
ede
check your charcole canister to see if it's saturated, since you can't find a leak. might want to preasure test the system to make sure
Old Oct 18, 2002 | 12:53 PM
iroc22's Avatar
The fuel filler necks for the gas tank aren't all that great on those Jeeps and it could be leaking around there under hard cornering and the fumes are coming up inside the interior.
Old Oct 18, 2002 | 01:22 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yep, I had the same problem with a couple jeeps. The filler necks are FS and the hose they use to connect the hard line to the tank gets worn dowm.
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Caspar
Jun 19, 2016 11:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
fastrs1891
South Central Region
Oct 20, 2015 09:24 AM
