What would it take to.....
Old Oct 18, 2002 | 04:01 PM
TBI305Camaro's Avatar
run a zz4 cam in a LO5? or maybe even a lt4 hotcam? Is it possible with the stock heads? Would I just need springs or what?
Old Oct 18, 2002 | 08:46 PM
springs?
Old Oct 18, 2002 | 08:57 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
it is reccomended you use screw in studs, but people have done without. springs, defineatly. i know GM sells a LT4 hot cam spring kit w/ everything you need spring wise
Old Oct 19, 2002 | 04:55 AM
ede's Avatar
ede
get springs to match your cam, and screw in studs are always a lot better choice then pull outs. don't get your springs from gmpp or k motion look at comp, lunati, or crane.
Old Oct 19, 2002 | 10:31 AM
so springs should be all i need then?
Johngypsy
Mar 2, 2014 06:04 AM
BluFBdy
May 20, 2011 08:28 AM
RoosterC
Oct 17, 2010 09:42 PM
88fastgta
Sep 9, 2010 06:25 PM
msstapleton
Jul 9, 2010 06:29 AM
