what causes high Hyrdo Carbons??
Old Oct 19, 2002 | 06:21 PM
breathment's Avatar
im having readings of 984 PPM at low idle. (900 rpms)
and 148PPM at high idle. (2000 rpms)
what is the cause of this? EGR or the cat or somethign else?
Old Oct 19, 2002 | 06:40 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
hydrocarbons is incomplete combustion
EGR really has nothing to do with this
EGR is used to regulate oxides of nitrogen (NOx)
the catylitic converter.....partly
Old Oct 19, 2002 | 06:43 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
A vacuum leak making one cyl "miss" intermittently at idle.
Unburned fuel from a "miss" can make HC levels be high.
A small vacuum leak would not be noticeable at higher rpms.
Leaking\dirty fuel injector(s) would make idle too rich.
Old Oct 19, 2002 | 06:46 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
check your plug wires, might have a bad wire.
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
