Dumb question - 23* heads?
Old Oct 20, 2002 | 04:40 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Can anyone explain what 23 degree heads are? What angle is 23 degrees?
Old Oct 20, 2002 | 05:03 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The 23* refers to the valve angle.
Stock heads are 23 deg too.
Other aftermarket heads are 18*, 15deg or less.
This requires a higher port but the valve is more unshrouded
and the combustion chamber is shallower. (easier to get a high cr with less or no piston dome.
A 18 deg head (or less) may require some addition piston valve relief
machining or "18 deg pistons". Have to allow for that in your budget.
Old Oct 20, 2002 | 04:29 PM
Marc 85Z28's Avatar
Along with special valvetrain, intake and exhaust manifolds!
MustangBeater20
Oct 29, 2022 09:20 PM
Mickeyruder
Sep 2, 2015 02:45 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
