Help with motor teardown
Old Oct 20, 2002 | 09:52 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I got the heads off the car, and will be adding new heads/carb/headers ASAP.
it gets cold here in the winter, and I doubt i'll have it done any time soon.
Will the engine be fine torn down out in the cold? the block still has antifreeze in it.
And my brother sprayed some wD-40 or liquid wrench down into the cylinders.
Any thing else I should worry about?
Old Oct 20, 2002 | 10:11 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Mark, if your going to rip the engine that far down and not finish in the near future it would make more sence to just pull the engine completly and cover it. After all if you rip the heads off your left with what 6 bolts, 8 including the starter holding the engine in.
Old Oct 20, 2002 | 10:16 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
WD-40 is ok for rust protection for couple days.
Get a can of Rust Check and spray it all over any exposed metal.
It will do a much better job.
Just wipe it off the deck surface when ya go to install the heads,
with some laquer thinner.
Cheap insurance..... try it.
http://www.rustcheck.com/
Old Oct 20, 2002 | 10:54 AM
Car: 99 Formula
Axle/Gears: 342
Thanks for the tip.
I'd pull the engine, if I had a garage or engine lift.
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
slade5612
Aug 11, 2015 07:19 PM
