Help: White smoke between engine and fire wall
Old Oct 20, 2002 | 06:13 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Here is an over view as to what I was doing at the time of the white smoke. I had the air cleaner lid off, both injectors dis conected. I was fogging the engine for storage. I didn't have the ijnition system disconected. I was cranking over the engine while a friend sprayed the fogg stuff down the TBI. and some white smoke started to come up between the engine and the firewall just to the left of the distrubutor, from a ground strap attached to the firewall. the smoke went away quite shortly after I stopped cranking the engine. Any thoughts as to why this white smoke would come from a ground strap connection on the firewall? The car is all put away now.. but if there is something I should have a look at please tell me.. Never seen this happen before.
Attached Thumbnails Help: White smoke between engine and fire wall-camaro-storage.jpg
eightsixseven
Dec 16, 2024 01:50 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
