Could this be a blown head gasket?
Old Oct 21, 2002 | 10:11 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
This actually isn't a Camaro question, but it's still GM at least.
My brother brought his '90 Bonneville home tonight to do an oil change. As he's finishing up and backing it off of the ramps, I notice some white smoke constantly comming from the tailpipe. I took a flashlight to the tailpipe (it was dark out), and there was definately a constant flow of white smoke. It was a little bit cool out (but not too cool for shorts and a t-shirt), so I figured that it must be because of the weather (you know how you see white smoke out of everyone's tailpipes on cold mornings). So I fired up my Camaro just to see if mine shot out smoke too... nothing.
I told my dad and he thought it might be a bad head gasket. He came out to take a look at it, and as he punched the accelerator in park, it would shoot out a billow of white smoke.
The tailpipe left a nice little puddle of (what I assume to be) water.
Is this cause for concern? Or might it have just been the weather?
Thanks!
Old Oct 21, 2002 | 10:44 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
its probably just condesation. One of the byproducts of combustion is water since gas is a hydrocarbon. If the gasket is blown, youd smell coolant. See if it is loosing iny coolant... Thatll tell you if the sytem has a leak somewhere,
Old Oct 22, 2002 | 07:32 AM
ede's Avatar
ede
if you think you have a head gasket problem do a compression test and you'll know for sure
Old Oct 22, 2002 | 07:49 AM
HIL87TA's Avatar
Engine: LG4
Agree you should smell coolant.:hail:
3rd gen money
Sep 8, 2015 11:40 PM
earlpote
Aug 28, 2015 10:42 AM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
