service engine soon light
Old Oct 23, 2002 | 12:17 AM
lunas's Avatar
i have an 87 trans am with a 305 tpi. It has 140000 miles on it. i hadnt driven it for a while, two weeks or so, then i took it for an hour drive on the freeway. the service engine soon light was on the whole way. as soon as i saw it i pulled over and checked everything, oil, trans fulid, i turned the off and on a ffew times but the light stayed on. i kept an eye on temp and oil press the rest of the trip but they were fine the whoole way. the next day i was goin to take it to a mechanic buyt the light was off and stayed off the whole time. should i be worried? anything i should check?
Old Oct 23, 2002 | 12:47 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
probably egr... code 32. Its probably coked up and not flowing after allt he years of service. See the teck articles on how to retreve codes. I believe they have a section on obtaining the codes in there.
Old Oct 23, 2002 | 12:48 AM
Car: 88 Camaro SC
Engine: SFI'd 350
oh... i wouldnt even bother worrying if it is a 32... i dont even have mine and it works fine but you can get preignition knock from the increased combustion temps.
Old Oct 23, 2002 | 01:21 PM
Vader's Avatar
Re: service engine soon light
Originally posted by lunas
... should i be worried? anything i should check?
Scan for error codes.
Old Oct 23, 2002 | 01:39 PM
ede's Avatar
ede
yep scan for codes the ses lite has notihng to do with oil and temp
Vintageracer
Jan 10, 2020 05:33 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
apie2546
Aug 10, 2015 05:43 PM
Omega
Aug 10, 2015 12:46 PM
