crankshaft sprocket removel
Old Oct 26, 2002 | 05:00 PM
firebirdgirl_87's Avatar
having problems pulling sprocket off crankshaft, have a cheap pulley and it keeps turning engine, not removing spocket. Any ideas on how to pull it off without turning engine? Buy a better pulley???
Old Oct 26, 2002 | 05:23 PM
ronterry's Avatar
Car: '94 Corvette
It sounds like the puller is binding on the snout of the crank. Does your puller have a bearing cap on the end of the main screw deal?
You can try some anti-sese on the end of the crank snout, or in the bearing cap if you have one.
Ron
Old Oct 27, 2002 | 01:16 AM
radiateu2's Avatar
gear puller
if the fly wheel is still on, put a screw driver thru one of the holes to bind the engine to keep the crank from turning. Then try turning the the bolt on the puller. Cheap or not if you can get the jaws on the gear and the bolt on the end of the crank you should be able to pull the gear off
Old Oct 27, 2002 | 02:51 AM
ronterry's Avatar
Car: '94 Corvette
Yea, done that & works good.
My newest tool to help is a piston stop. Just pop it in one of spark plug holes and your set.
...also if the screw is allow to turn in the cup, there wouldn't be any force turning the crank while pulling the sproket off. I've done this on bearing seperators, just put a socket between the screw & the crank snout. Most harmonic pullers have screw cups, and that what I use also.
Oh yea, make sure your not drilling into the crank with that screw. Thats a good way of stripping the crank threads.
Ron
Old Oct 27, 2002 | 03:03 AM
radiateu2's Avatar
puller
yeah the socket trick works and if ya want to Sears has a nice puller I just bout with all of the attachments that go on the und of the bolt. Its nice but spendy at I think I paid 40 for it but worth it I think
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
LT1Formula
Aug 20, 2015 09:36 PM
