Space between flexplate and torque converter?
Old Oct 27, 2002 | 01:47 PM
GilmourD's Avatar
I just dropped my engine in and went to bolt the TC to the flexplate, and there's a good 1/2 to 3/4 of an inch between the TC and the flexplate. The flexplate is on with the counterweight facing the engine and the bolt-hole bulges facing towards the TC. Is the TC pushed too far onto the input shaft of the tranny?
Old Oct 27, 2002 | 02:19 PM
GilmourD's Avatar
Old Oct 27, 2002 | 03:31 PM
Birdman7389's Avatar
sounds like it.... just bolt em up, is the convertor an aftermarket unit or a stocker? I had the same dilemma with an A.C.T. convertor, but it turned out to be no problem
Old Oct 27, 2002 | 03:35 PM
GilmourD's Avatar
So, just pull the TC closer to the flywheel? It's a stocker, BTW. I'd love to get an aftermaket one, but don't have hte cash yet.
Old Oct 27, 2002 | 09:11 PM
Guest
Guest
Posts: n/a
Yea, as long as the bellhousing is flush with the back of the block, you're ok. There is some space if the converter is pushed all the way back into the tranny.
Old Oct 27, 2002 | 09:57 PM
I agree, should be no problem.
Old Oct 27, 2002 | 10:04 PM
GilmourD's Avatar
OK, good. My dad was working on it and he's under the car like "Damn Chevy. Should've gotten a F@#$"... I'm the weird one out of the family. Everybody else has Rustangs.
Old Oct 28, 2002 | 12:27 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
they are made like that so you can fit the tranny where it needs to go. Think if the converter was always out far enough to touch the flexplate how much harder would it have been to get the flexplate/converter AND the bellhousing/engine to line up ALL at the same TIME?
its made like that on purpose you see.
I remember once I thought I had the converter on all the way (it wasnt) and i was bolting the bellhousing to the engine using an air-ratchet and I hear BAM!!! well guess what the converter was touching the flywheel and the pressure against it cause the bellhousing to crack oh well 5 bolts is just as good
Stangski09
Nov 14, 2015 01:27 PM
88rscamar0
Sep 23, 2015 09:08 PM
Nick McCardle
Sep 10, 2015 08:36 PM
roysatikas
Sep 7, 2015 08:08 PM
