need tpi 305 heads
need tpi 305 heads
HEy guys i have a LO3 and everyone tells me that i need to buy the tpi 305 heads because the tbi heads blow!! well where can i find them, ebay doesnt have them and the junk yards are tryingto rape me for them... plus what else should i swap out or get new while i put these in... i was thinking 305 tpi heads and intake... and leave the throtle body injection b/c i cant afford tune port. thanks.
Car: 99 Formula
Axle/Gears: 342
Well, yes the TBI heads suck. You don't need TPI heads but they'll be better.
I have a pair of heads for sale off my 350 12k miles on them, PM me for more info.
Car: 84 Trans Am
mark your heads off your 350 suck, and thats on a 350. on a 305 they would be even worse cause he would lose so much compression with those 76cc heads.
Car: 99 Formula
Axle/Gears: 342
course, if you can afford aftermarket ones, go for them, I'm just offering these cheap as an alternative, never said he should buy them.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The heads you are looking for have a casting # that ends in 081.
They will be even better after some porting and new 1.94 intake valves. These heads have the right 58cc chambers for your 305.
Might be able to buy them at a good price rebuilt from a
auto parts chain store like pep boys.
Or try Wheeler Motorsports.
Transmission: 4L80E/4L80E
LG4 or L69 heads (416 castings) have the same basic port and chamber design as the LB9 heads. The only difference is the center two intake bolts will be at a different angle, but all you have to do to fix that is elongate those bolt holes in the intake manifold.
'87 LG4 heads will be the same as LB9 heads, and have the same bolt angles as your LO3 intake manifold.
Some people might just happen to have a set of LG4 heads sitting around that they'd be willing to part with for the cost of shipping. Those heads may need a rebuild, though (guides, valve job, valve springs). Hint, hint...
Fast355
Dec 2, 2016 06:33 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
