Does anyone elses car do this?
Old Oct 28, 2002 | 07:42 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
When i have below 1/4 tank of gas and i take a right hand turn the car will begin to spudder and in some casses under extreme turns will stall out. I had the fuel pump replaced n that didnt help is there something else i could do to fix this like some sort of aqumulator?
Old Oct 28, 2002 | 07:59 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Keep your tank 1/2 full. On these cars, 1/2 full really means 1/4 full, and 1/4 full really means 1/8 full. What is happening is you are pulling the little bit of fuel away from the pickup. No fuel to the engine means dead engine. The other problem that arises is that you may run the mixture dangerously lean and FUBAR something.
Old Oct 28, 2002 | 08:16 PM
silverstreakII's Avatar
other than simply keeping the tank more full, switching to a dedicated fuel cell or baffled tank is the only option. a pricey option, but definately trick.
Old Oct 28, 2002 | 08:39 PM
TBI305Camaro's Avatar
yeah mine does that. My gauge is messed up and wont read after half tank so thats how i know when im in need of juice.
Old Oct 29, 2002 | 09:29 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
If mine has less than 1/4 tank, it'll starve the fuel pump on a tight turn too. Be careful, it's hard on the pump and I'm sure you know what a pain it is to replace one. Just do like I do and fill it when it gets to 1/4 tank.
-Rich-
Old Oct 29, 2002 | 10:15 AM
yeah the pumps are a pain in the ***. Id do that if knew how much gas i have. Guage is screwed up. I think i messed up the sender whenever i change the pump. I usually keep it about half tank tho. it hasnt ran for a month so i havent had to worry about it for awhile.
jhawkeye
May 25, 2022 06:33 PM
midge54
Dec 27, 2019 04:14 PM
TheExaminer
Aug 26, 2015 04:59 PM
Linson
Aug 21, 2015 02:12 PM
mustangman65_79
Aug 8, 2015 12:07 PM
