Need help with a decision
Old Oct 29, 2002 | 06:15 AM
TunedPortZ's Avatar
ok guys im having a dilema(spelling?) right now, here it is: i really want to build a 406 for my 86 iroc, and i was planning on starting next spring, now heres the problem this winter i was planning on porting a set of 305 heads i have so i could be faster at the strip next spring. Now should i go ahead and spend a little money on the 305 heads now, and maybe wait a little longer on the 406. Or save all my money for the 406? thanks guys
Old Oct 29, 2002 | 07:09 AM
FORMULA355TPI's Avatar
Car: 88 FORMULA / 88 IROC
Engine: 355 / 355
Transmission: T5 / TH400
Axle/Gears: 10 Bolt-3.73 / 9"-3.90
If you have a 406 in the works only do what it takes to keep the 305 running long enough till its done..
thats my $.02
Old Oct 29, 2002 | 08:31 AM
jimmy_mac's Avatar
Ye, I'd put all efforts into the 400. Why burn yourself out on something you are not going to keep for very long. It also seams like you would be running a much quicker 60ft with those mods. That 60ft looks like an unmodified LB9 run. Seams like you could pick up some e.t. from somewhere esle without messing with the heads. I mean it looks like something isn't working right. Didn't notice if you added a slightly higher stall converter or not. Not that you need that much more but a good launch would help out.
Old Oct 29, 2002 | 09:46 PM
TunedPortZ's Avatar
yeah, i know. my tires suck and i spun alot...... im sure i can run a 9.4 with traction
Old Oct 29, 2002 | 10:06 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
I agree with the rest. Don't spend money on something that will be sitting in the garage in a little while. I'd just be patient and sink the money into the 400!
Good luck!
ZZ3Astro
Aug 13, 2019 12:57 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
3.8TransAM
Sep 3, 2015 06:38 PM
BlackTopKing
Aug 19, 2015 12:13 PM
