Crazy fuel tanks!
Old Oct 26, 2002 | 02:33 PM
colonboy14's Avatar
Car: Trans Am
Crazy fuel tanks!
Lately, I've been having a lot of problems fith my fuel tank. First, the gauge is not right at all - it will stay on full for a while and then shoot down, etc. I was thinking that it was just the sender that was bad. But the other day I "ran out" of gas with 7 gallons left, and the mechanic said the baffles in the tank might be broken. Anyone else have this problem? Solutions? Thanks.
Old Oct 28, 2002 | 05:01 PM
helloriker's Avatar
I have that problem with my Grand Prix, havn't taken it to a mechanic yet. But It could be a bad sending unit or a bad float. Either way it is not cheap to replace if you go to a shop to do it. They charge 8hrs of labor or so. Just finished or rather almost finished replacing the fuel pump on my GF's camaro. Waiting on the springs to get here to finish putting the car back together. We figured since the rear suspension needed to be dropped and she has worn springs and shocks we might as well replace them while we are down there
Old Oct 28, 2002 | 06:18 PM
Rage13's Avatar
Car: 89 Firebird
mine dose about the same thing, first half of the tank it reads full, then on the half mark i have 1/4 tank.. never even thought about fixing it
Old Oct 28, 2002 | 07:25 PM
helloriker's Avatar
neither have I simply cause if it is a bad float it ain't a cheap part. So I just go by the trip odometer. I know that I get roughly 26 mpg and my tank hold 13-15 gallons so as long as I gas up every 270 miles or so I should be fine
Old Oct 28, 2002 | 07:27 PM
Bort62's Avatar
Well Im pretty sure its not the baffles in the tank considering there are None.
Sounds like the sender is screwed. Go pick one up at a junkyard.
Old Oct 28, 2002 | 07:42 PM
Rage13's Avatar
Car: 89 Firebird
26 mpg? what kinda motor you have? i've got a 305 stock and get about 10 mpg, and thats taking it easy on the gas....
Old Oct 29, 2002 | 04:13 PM
helloriker's Avatar
the grand prix has a 3.8 ltr V6 with 200 hp. It ain't a lot of hp but it gets me where I am going as fast as traffic will allow
Old Oct 29, 2002 | 04:22 PM
Rage13's Avatar
Car: 89 Firebird
i only have 160 hp...
Old Oct 29, 2002 | 10:11 PM
helloriker's Avatar
my gf brother has a 2000 trans am m6 that gets 23 mpg and has 330 hp
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
