Tire problem...outside wear
Old Oct 29, 2002 | 12:34 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Guess I'll post this here. My passenger side front tire is wearing badly on the outside. The driver's side doesn't show this wear. Is this a ball joint problem or an alignment problem. I will be getting new tires next week probably and then an alignment, but I'll do the ball joints before if that's the problem.
Thanks all.
Ed
Old Oct 29, 2002 | 12:49 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Have you checked the ball joints to make sure they are tight?If so..your alignment is out.If there is slop in the ball joint that will definitely cause wear..change it if so and then get the car aligned.If ball joint is tight,,you may have to much positive camber or excessive toe.
Old Oct 29, 2002 | 12:50 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
I have the same exact problem. and if I jolt the car from right to left it makes this popping noise kinda like the lugs arent tight but I checked em and there all good. what could it be??
Old Oct 29, 2002 | 01:05 PM
ebmiller88's Avatar
I think I'll just bite the bullet and replace the ball joints anyway. Couldn't hurt after 80K miles.
Thanks..
Ed
Old Oct 29, 2002 | 02:38 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Hey ed I'm up here at Winthrop in Rock Hill. Where are you? We should meet up sometime.
Old Oct 30, 2002 | 08:38 AM
ebmiller88's Avatar
Cool!
I live in Fort Mill and work for Duke out at Catawba Nuclear Statioin.
Ed
Old Oct 30, 2002 | 09:25 AM
Thundering Z03's Avatar
Car: 92 Camaro Heritage
Engine: 305 TBI
I'm not my any means saying that this is your problem. More than likely its what was mentioned before, but just for the record, I'll say what happened to me. My car had the passenger tire wearing on the outside too. I had the alignment checked out, and it was alright. The tire dealer gave me this diagnosis, and it actually made sense. My driveway was a SHARP left hand turn on concrete. (A complete lock of the steering to the left) The daily turn in and out of that sharp turn on concrete was eating my tire to bits. I just changed my way of turning onto the driveway so It wouldn't be as sharp. No more problems since.
Old Oct 30, 2002 | 10:07 AM
cdogc350's Avatar
that bump sounds like a ball joint. ..did you check it with the car unloaded. ANY movement in the ball joint...even the slightest..requires a new one.
Old Oct 30, 2002 | 10:48 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Yea it is movin a little. How do I go about changin one of these??
Old Oct 30, 2002 | 12:28 PM
No4NJunk's Avatar
yeah I know where the catawba plant is. Why are you guys always setting that alarm off?? Or is that someone else?
Old Oct 30, 2002 | 02:45 PM
flyway190's Avatar
I don't know, but I can tell you this: Before my passenger-side tire slammed into my fender and skidded across the highway when my ball joint separated, I'm pretty sure it did have that kind of wear, even though there wasn't any movement verifying the ball joint was about to go. There was however, a loud pop that occurred when I would go over a large bump that sounded like something was popping into place, then later popping back out. It went away after I replaced the bushings and ball joint so I'm not sure exactly what was the culprit. It mysteriously quit popping the day before the ball joint separated... I heard that if the grease fitting is receding into the joint then the joint should be replaced.
Believe me, having a ball joint go out while you're on the highway is worse than having your hood fly off! Hope this helps.
Old Oct 31, 2002 | 07:26 AM
ebmiller88's Avatar
Alarms... What alarms??
I do have a sharp left turn that I usually take to get into the driveway..quite possibly it. It's a left hander that then goes up a littleand then levels off. I've been meaning to fill that curb in....
Gonna order ball joints today.
Thanks..Ed
Old Oct 31, 2002 | 11:07 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Please post the price, manufacturer and place of purchase for the ball joints. I need some too.
Old Oct 31, 2002 | 12:18 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Ball joints are around $25-40 depending on where you get them. Any auto parts store will have them in stock.
I've also heard that if the bushing at the top of your strut mount is worn that you can get the same type of wear.
On my GTA I replaced the passenger side ball joint but not the driver side. Now 10k miles later, the driver side tire is shot on the outside edge.
Old Oct 31, 2002 | 12:24 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
MCQUAY NORRIS FA921 $11.99 thats in stock at kragen. damn good price!!!!!!!!!!!! it has a lifetime warrenty too. do they make thse in polyurithane??
Old Oct 31, 2002 | 02:27 PM
ebmiller88's Avatar
Ball joints wont' come in poly, they're a metal piece that you have to lube up.
I use Moog P/N K6145 joints, $25 each. Got them thru Summit, I needed an ES torque arm bushing for my RS, too.
Thanks guys.
Ed
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
brockerboy
Wheels and Tires
Sep 17, 2015 03:59 PM
F-body-fan
Sep 17, 2015 12:16 PM
2MNYMaros
Sep 15, 2015 11:36 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
