Argh!!!! $@@# %%#^
Old Oct 31, 2002 | 05:42 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Argh!!!! $@@# %%#^
Well... the car left me walking again... on the highway.
But some dude gave us a ride home.
Ok... started running real bad, surging the idles... BACKFIREING..
sound like the timing chain is slipping.
when i tryed to go it felt like something was slipping in the engine like the timing chain on the sprokets.
Is this the timing chain?
I couldn't get it to idle after.
help
Old Oct 31, 2002 | 06:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably not... they usually either work, or they don't. If it doesn't, the car doesn't run, period.
Surging & backfiring sounds like a fuel delivery problem: it's way lean. Have you changed your fuel filter lately?
Old Oct 31, 2002 | 06:22 PM
Yep recently changed it.
The cap came loose on my distibuter the other day and ****ed up the cap and rotor. Same symptems that I am having now but the cap is on tight. We replaces the cap and rotor.
We took the #1 spark plug wire and in inside came out. they must be ****ty wires so we just pushes it back in.
I also have more than 1/2 a tank of gas.
Old Oct 31, 2002 | 08:41 PM
>Update
got the car home.
The car now:::
Starts but Immedietly Stalls.
Fuel pump or relay?
dans82bird
Carburetors
Sep 3, 2004 11:00 AM
D Stroy H8
May 6, 2004 01:50 AM
85_ZED28
Apr 26, 2004 05:09 PM
Hype
Oct 4, 2003 01:47 PM
CheezX
Jun 10, 2002 06:41 PM
