motor swap?
Old Nov 1, 2002 | 11:47 AM
ionicswing's Avatar
motor swap?
what do i need to switch my v6 to a 350?
Old Nov 1, 2002 | 11:52 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
tranny, motor mounts, bigger radiator, heavier duty coil springs, if you're doing fuel injection on the v8 then you'll also need the wiring harness and ecm
Old Nov 1, 2002 | 12:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The easiest way, in 2 simple steps:
Step 1: Sell the 6-cyl car
Step 2: Buy a V8 car
The next easiest way is to get a whole V8 car, and swap everything from it to the 6-cyl car. This is a whole lot harder and will probably cost more money.
THe hardest and most expensive way is to try to buy each piece individually. You can probably buy 2 whole cars for what the parts will cost you that way, and it will be many times as much trouble, as you try to figure out what it is that you don't have but you need.
Old Nov 1, 2002 | 02:17 PM
Morley's Avatar
Re: motor swap?
A whole lot of time, patients and MONEY.
Old Nov 2, 2002 | 05:37 PM
pskel350's Avatar
if you have basic knowledge and the right tools it wont be that hard. just make sure you have all the parts, the easiest way is to buy a v8 parts car for cheap. i did the whole swap and had my engine running, but not tuned, in about a week. that is working at my job full time and working on the car nights. it is worth doing, the difference in power is great. it isnt that hard, i got my parts car for free, but other than that i spent less than $300. good luck, in my opioning it is a lot cheaper than buying a v8 car. good luck!!
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
