timing?
Old Nov 1, 2002 | 09:04 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
timing?
which way do u turn the distributer to make it more lean or more rich? thnks
Old Nov 1, 2002 | 09:13 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
turning the distributer will not make it run any richer or leaner. all that does is control the ignition timing or basically when the spark plugs fire.
Old Nov 2, 2002 | 07:42 AM
ede's Avatar
ede
changing the timing will or can have some bearing on how rich or lean an engine runs, but you really want to be adjusting your A/F ratio.
Old Nov 2, 2002 | 09:19 AM
SHAGME's Avatar
Car: 1988 IROC-Z
ok thnks Ill read up on that.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
