gm part# for 3\4 wire O2 sensor..
Old Nov 3, 2002 | 01:57 AM
breathment's Avatar
i want to replace my O2 sensor with a 3\4 wire O2 sensor.. so i did a search and i found specific part #'s for bosch and AC Delco. but my local autozone doesn't have AC Delco O2 sensors. only bosch and i heard some bad things about them. and how AC Delco is better.. i haven't tried Napa or Pep Boys.. but i thought about seeing how much they are from gmpartsdirect.com i just need a part #
Old Nov 3, 2002 | 04:36 AM
ede's Avatar
ede
sorry no pn, but it may be easier to find out what car or truck used 3 or 4 wire and ask for one to fit. as far as i know all are the same only harness and length of wire is differant and you'll be wireing it to fit your car so that wouldn't mastter.
Old Nov 3, 2002 | 12:11 PM
breathment's Avatar
are the GM units better quality then Bosch and AC Delco?
Old Nov 3, 2002 | 08:00 PM
shepherm's Avatar
I think the 1991 chevy full size vans had a 3 wire.
Old Nov 3, 2002 | 08:19 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The AC Delco # is 213-632 '91'vette ZR1
Last 3 numbers of the GM part# is 708 maybe they can cross it for you.
Old Nov 3, 2002 | 09:45 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The 213-632 was used in lots of applications for GM. Check the cross-reference chart at http://www.acdelco.com/html/catalog/index.htm.
Check CorvetteForum.com out. There's a tech article about heated 02 sensors there. The author mentions he used a Bosch 13190. It retails for about $43 at Advance. The oxygen sensor is for a Chrysler mini-van application. The ZR-1 sensor is Bosch 13077.
I believe the general consensus is that Bosch manufactures the majority of oxygen sensors. Even that AC-Delco or original GM is probably made by them.
Old Jun 20, 2004 | 04:54 AM
thecoolone's Avatar
Car: 89 GTA
Not to re hash, but I also recently went looking for the part number for a gm O2 sensor and didn't find anything here so I looked elsewhere and I came up with 25162693
I believe thats correct. Not trying to archive incorrect info.
Correct me if I'm wrong.
davidopliger
Feb 3, 2025 09:30 AM
Spike_Akers
Sep 29, 2012 03:06 AM
glock
Sep 9, 2007 11:26 AM
FastElectrics
Jan 29, 2001 07:24 PM
