Leaking AFPR...again?!?
Old Nov 4, 2002 | 02:07 PM
l98mac's Avatar
Less than three months ago I had to replace the regulator due to a bad/leaking diaphram. The car had been sitting for two years, so I figured that may have played a role. Now the new regulator is doing the same thing which is: Slowly leaking fuel out of the bottom. I can see moisture under the plenum, and when I stick my finger down there it comes back with fuel on it. Also, there is a stain where it looks like fuel is coming from the line you pull to check FP at simulated WOT. Any ideas why this keeps happening, and a possible fix? A new regulator every 2 1/2 months isn't very economical for me.
Thanks in advance for any replies.
Old Nov 4, 2002 | 02:17 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I had the same problem but discovered that it was actually the fuel line that goes into the front of the FPR housing. It's not hard for that line to get bent slightly, which will cause it to leak. After 2 unsucessful attempts to straighten it, I finally just replaced the rail with a better one.
Old Nov 4, 2002 | 02:21 PM
l98mac's Avatar
That makes a lot more sense than it being another bad regulator. So you replaced the whole rail? Is that a very expensive/difficult undertaking? Thanks for the quick response by the way.
Old Nov 4, 2002 | 04:19 PM
Jim85IROC's Avatar
I replaced the whole rail. I saw no way to separate the fuel line from the rail. Both lines were welded together at the bracket that bolts to the front of the intake manifold. For $50 I got a complete used fuel rail. I polished it, painted the steel lines and put all new rubber o-rings in. I wound up with one that looked like brand new for a minimal cost. Now I've got a bunch of spare parts that I'll never use too.
Old Nov 4, 2002 | 06:42 PM
l98mac's Avatar
That's not nearly as bad as I thought. Well I'm going to do some more investigating to see if my problem is like the one you had. Thanks for all the info.
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
