thermostate
Car: 99 Formula
Axle/Gears: 342
Depends.
On a computer controlled car, I'd go with a 180*, on a non CC car 160*.
180* minimum rating if you have to drive it in the winter, I see you're in NJ.
160* summer if non cc.
But, don't forget, a lower stat won't help much, if you have a temp fan switch, stock setting is around 227* or so I believe, I'd wire up a much lower one.
Me, I'm a crazy ****. 180* tstat, fans on all the time.
The car will ride at about 180-185 all the time. With my stock fan, I noticed it wouldn't kick in until 200 or so, but I'd get the most... feel out of the car at around 180-185 and it kinda lost something above that. I hope things will be the same with the new engine. LOL
The car will ride at about 180-185 all the time. With my stock fan, I noticed it wouldn't kick in until 200 or so, but I'd get the most... feel out of the car at around 180-185 and it kinda lost something above that. I hope things will be the same with the new engine. LOL i have a 350 over .40 and i run a 160* with my single stock electric fan from my 2.8L. I wired my fan to run all the time but the car runs at 160* all the time, it gives me excelent performance. i do have a 3-row radiator though, but i think you would get the same out of a good stock radiator. i just upgraded cuz i didnt have a V8 one when i did the swap.
Car: 1987 Z28
i just want my car to be cooler well actually i dont have a thermostat in my car right now nd i wanna put one in but i want one that will run cooler so im guessing the 160 is good
Car: 99 Formula
Axle/Gears: 342
Originally posted by ede
if you don't have anything in it now it'll run hot or hotter than if it had a t-stat in it, you need the restriction to allow heat to transfer to the water ,or coolant.
Car: 1987 Z28
Originally posted by Vader
That would probably be fine in an LG4, but if you have the TPI engine and stock EPROM, I'd suggest the 180°F.
y what would be the diffrence
Car: 99 Formula
Axle/Gears: 342
kitt_2000
Aug 5, 2013 08:58 PM
kendog_85_305
Carburetors
Feb 10, 2004 09:41 AM
87_Camaro
Aug 9, 2001 03:41 PM
