I'm an IDIOT.......help anyone?!??
Old Nov 6, 2002 | 04:17 PM
aklaim's Avatar
This sounds sooo dumb, but can somebody tell me how to get the stock windshield wiper blades off? I just bought some new Bosch blades for my car (not refils) and I cant for the life of me get the old of ones off. I have a big storm coming and i dont think the stock blades were ever replaced. Help anybody?!?!?
thanks,
-BJ
Old Nov 6, 2002 | 04:30 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Kind of hard to explain, but I believe there is a tab that you need to flip out, in order to get them off. Just takes some playing around with.
Old Nov 6, 2002 | 04:56 PM
aklaim's Avatar
I wish it was that easy. Ive screwed with the damn thing for an hour and cant see how it comes off....
Old Nov 6, 2002 | 05:04 PM
Car: 99 Formula
Axle/Gears: 342
Right in the center where the 2 pins or so are, I'm going off of memory here, sorry. I had to use my keys to open the clasp/lever whatever you want to call it, and it folds out.
Old Nov 6, 2002 | 06:01 PM
Vader's Avatar
A thousand words is just too much work:
Old Nov 6, 2002 | 06:04 PM
Car: 99 Formula
Axle/Gears: 342
Yup, I would have but the car is about 200 miles away...
Old Nov 6, 2002 | 06:28 PM
aklaim's Avatar
Thanks guys, but i dont know what that is but it sure isnt on my car. All i want to do, is remove the windshield wiper. NOT the whole arm. Here's a pic of what im trying to get off...
Old Nov 6, 2002 | 06:29 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
was he talking about removing the entire arm, or just the blades themselves?
Old Nov 6, 2002 | 06:32 PM
oh, ok... where the arm attaches to the blade, there should be a small plastic clip on the underside of the blade that needs to be pressed in. after doing this, the blade should release if you move it back towards the arm.
Old Nov 6, 2002 | 06:34 PM
Car: 99 Formula
Axle/Gears: 342
yep, that's what i thought too, guess Vader was thinkin somethin else, I didn't want to challenge what he was thinking.
Old Nov 6, 2002 | 06:35 PM
aklaim's Avatar
And this will take the entire piece off not just the rubber blades?
Old Nov 6, 2002 | 06:36 PM
Car: 99 Formula
Axle/Gears: 342
yes
Old Nov 6, 2002 | 06:37 PM
aklaim's Avatar
You guys RAWK! Thanks much.
Old Nov 6, 2002 | 06:50 PM
aklaim's Avatar
Okay I spoke entirely way too soon. They dont come off. I almost broke it trying to get the old blade back in. There is a spring and a retainer clip that holsds everything on. The only thing i guess that can be done is buy blade refills.
Old Nov 6, 2002 | 09:29 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
my car's not here and i can't remember which type of attachment our cars have but there are only two different ones. i've made a drawing of each type. if you have the type on the left, there's a metal pin that goes through the wiper and you just have to stick a screwdriver between the wipder and the arm as close as you can to the pin and twist, it'll pop right off and the new just snaps back in place. if you have the type on the right, there's a hook in the wiper arm with a hole at the tip. the wiper slides into this hook and snaps in place with a tab/clip and you need to push on the little tab from the bottom side of the wiper, above the rubber but below the metal part.
Old Nov 6, 2002 | 11:21 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
lol... dont feel too dumb... i had the same problem, but i have an extremly short attention span. I just broke them in half after about a minute of scrathing my head to get them off the wiper arms.
Old Nov 7, 2002 | 12:43 AM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
I had the same problem. After messing with the stupid things for a good 15 minutes, I just said srew it and grabbed the hacksaw off the wall. Took no time at all after that. Just be careful not to cut anything you're not taking off.
Old Nov 7, 2002 | 10:08 AM
Zeke3Elevn's Avatar
Mine were being stubborn so i went at it with a pair of plyers and a screw driver... finally got it off ...
Jesus Mark, it would be nice if i read one thread that you didn't post in yet because we all know you'll get to them all eventually
j/k
Old Nov 7, 2002 | 11:04 AM
Yikes Guys!! Hacksaws? Pliers? Breaking things in half? I realize that these things can sometimes really be a PITA to replace, but no need to get THAT angry!!
Old Nov 7, 2002 | 11:31 AM
aklaim's Avatar
Thank you Dimented24x7. All you have to do is geta flat head screw driver and place it inbetween the wiper and arm. Turn the screwdriver so it forces the wiper up......then just pull it off. Thanks again.
Old Nov 8, 2002 | 08:32 PM
jizzyz28's Avatar
turn the blades on cut off the car when they are half way up, then take the blade bend it in half take a flathead and pop them off
Old Nov 10, 2002 | 07:40 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
just dont do what i did.....tried to be gentle.....broke the end of my arm off(the wiper arm not mine)
oh well when you can bench 390 pounds...gentle takes on a whole new meaning when dealing with stock 83 parts...lol
