406 or 377
Old Nov 6, 2002 | 09:37 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
406 or 377
me and a buddy are putting together an 85 Cutlass with a 406.
my question is would you go with the 406 or would you destroke it and go with a 377.
i need details
Old Nov 6, 2002 | 09:48 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Where do you want your power? lower in the rpm band or higher, destroking makes for high winding engines that require QUALITY parts for longjevity. Not real useful for a street car, race car yes.
Old Nov 6, 2002 | 10:03 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
A 406 will put out more peak HP and TQ. Are you willing to sacrifice low RPM torque for higher RPM HP above 6500?; because that's the only place the 377 is gonna make more power than a 406, all else being equal.
I know. Why don't you just pull it and put in a 350? That's a much easier and less expensive way to get less displacement and less power?
AJ
Old Nov 6, 2002 | 10:35 PM
Guest
Guest
Posts: n/a
Destroking will cost more, and you'll get less.
Stick with the 406. Dont try to make things more difficult.
Old Nov 7, 2002 | 03:06 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
do a 406
Old Nov 7, 2002 | 06:30 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
heavy car like a cutlass..? go with a 400
Old Nov 7, 2002 | 07:37 AM
91banditt2's Avatar
Engine: 5.7 HSR
well i surely don't want to make things more difficult
what kind of RMP range does a 406 have?
here's what i thinking about doing
406
5.56 rods
400 crank
flattop pistons
500ish lift 270-280 duration cam
1.6 RR's
a set of recondictioned heads
2.02-1.60 valves
160cc runners(i know that'll be a restriction down the road)
single plane intake
700-750 cfm carb
our goal is to get it running into the high 13's low 12's.
Old Nov 7, 2002 | 08:44 AM
laiky's Avatar
if your going to use the 5.56 you should upgrade to the 5.7 rods it wont cost more than the rods, except you need to get the pistons with a higher pin height. You should also balance the assembly too
Old Nov 7, 2002 | 09:10 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
stock 400s will go 6000+
I know someone that would spray 200shot with a stock bottom end and still twist it 6500. I don't agree with the logic,, but its doable.
Select a good piston/rod combination and use a good cooling system. You will never have to mess with it again.
Old Nov 7, 2002 | 09:14 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
do the 406, unless you are wanting to do a little round track racing.
Old Nov 7, 2002 | 09:40 AM
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
mine can go to 6400.. but if it seeing even 6000 its a miracle.. i usually done go past 5800-5900
C409
Sep 23, 2015 04:30 PM
mddaniel
Sep 8, 2015 05:16 PM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
trevor1010
Aug 24, 2015 11:29 AM
