stroker motor question
Old Nov 6, 2002 | 11:12 PM
fastredtruck's Avatar
Car: 88 gmc 1500
Engine: 496
Ok Assuming both motors have the same heads, cam, compression ratio, intake, carb ,ect. wich motor will make more power?
A 400 block .060 over with a 350 crank and bearing spacers wich is like 382 cubes.
OR
A 350 block .030 over with a 400 crank to make 383 cubes.
Old Nov 7, 2002 | 12:03 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
These combos are basically like the old 377 vs. 383 debate. The destroked 400 will make more high rpm HP, while the stroked 350 will make more low end torque. I'd say they are basically equal it just depends what rpm level you are wanting to make power at.
Old Nov 7, 2002 | 12:07 AM
iroc22's Avatar
The 383 would be way better off on the street and the 382 would be a way better circle track or trans am engine.
Old Nov 7, 2002 | 07:07 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The correct combo you didn't list: the 400 block with the 400 crank.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
Cleotiz
Jan 6, 2018 08:56 PM
mhatfield 14
Oct 24, 2015 07:48 AM
redmaroz
Aug 16, 2015 11:40 PM
